Posted November 23, 201311 yr comment_436734 Anyone know if I have a correct manifold for my 1/70 build ? One is marked N36 on the casting and has two bolts to presumably mount a heat riser tube and the other manifold is marked E30 and has no bolt holes for a heat riser. ThanksBrian Link to comment https://www.classiczcars.com/forums/topic/48017-series-1-exhaust-manifold/ Share on other sites More sharing options...
November 24, 201311 yr comment_436743 My 3/30 car had the manifold that has no bolt holes, and the corresponding carb head shield without the upside down "U" cut out in the center for the heat riser. My 4/71 car has the N36 manifold. Link to comment https://www.classiczcars.com/forums/topic/48017-series-1-exhaust-manifold/#findComment-436743 Share on other sites More sharing options...
