Email logins are now active ×
Flywheel
Pomorza
I have just a teeny bit of 510 knowledge now (little knowledge = dangerous), and I can tell you that L16 and L18 cranks/flywheels have 5 bolts and have 200mm diameter clutches. L20B's however have the 6 bolt cranks and you can use Z flywheels all you like on them.
It would then be incorrect to state that all L's have the same flywheel requirements. Also don't forget the 280z and ZX 2+2's also had the 240 mm flywheels, not just the ET's.
  • Who's Online   1 Member, 0 Anonymous, 429 Guests (See full list)
