just bought my self a 73 Z having a few issues
spiffy240z
Well I was rushing to get back to my car. Now i'm having issues with my driver side outer door handle. The rod that connects to the door handle, pushes a tap down to open the door. The rod keeps popping out of the tap. Is there supposed to be a nut at the end of the rod to prevent that?
  • 1 month later...
The little clip that holds the window knob on can easily be removed by pulling the center of a rag behind the knob and pull the rag back and forth. the rag will catch the end of the clip and pop it off..Those clips in Portland are known as Dammit clips because you can't find them after removal.
Mark in Portland
  • Who's Online   2 Members, 0 Anonymous, 783 Guests (See full list)
