December 16, 201311 yr Author comment_437956 Well I was rushing to get back to my car. Now i'm having issues with my driver side outer door handle. The rod that connects to the door handle, pushes a tap down to open the door. The rod keeps popping out of the tap. Is there supposed to be a nut at the end of the rod to prevent that? Link to comment https://www.classiczcars.com/forums/topic/48145-just-bought-my-self-a-73-z-having-a-few-issues/?&page=2#findComment-437956 Share on other sites More sharing options...
December 16, 201311 yr comment_437961 ajmcforester said: If your getting rid of the emission parts let me know I could use a good smog pump and one of the hoses.I've got a pump from (I believe) a 260 and a couple of the braided style hoses. PM me if you're interested. Link to comment https://www.classiczcars.com/forums/topic/48145-just-bought-my-self-a-73-z-having-a-few-issues/?&page=2#findComment-437961 Share on other sites More sharing options...
January 16, 201411 yr comment_439783 The little clip that holds the window knob on can easily be removed by pulling the center of a rag behind the knob and pull the rag back and forth. the rag will catch the end of the clip and pop it off..Those clips in Portland are known as Dammit clips because you can't find them after removal.Mark in Portland Link to comment https://www.classiczcars.com/forums/topic/48145-just-bought-my-self-a-73-z-having-a-few-issues/?&page=2#findComment-439783 Share on other sites More sharing options...
January 17, 201411 yr comment_439808 better do a complete overhaul of the brake system, this is something you don't want to save money on ! Link to comment https://www.classiczcars.com/forums/topic/48145-just-bought-my-self-a-73-z-having-a-few-issues/?&page=2#findComment-439808 Share on other sites More sharing options...
