Put a new 3 row brass and copper 280 radiator in my '72 240 and a full shroud. Radiator fit great just hangs lower because of the added transmission line cooler cavity. Dumb a## me didn't get all the parts before I started so I'll have to wait until Monday morning for the different shape lower hose, every chain store has the upper but no lowers. Beers are on me, literally.
I pulled off the intake and exhaust on the 260Z today.
After I pulled off the carburetors, I noticed this...
I knew I had an exhaust leak. I just didn't know the manifold was trying to snap in half.
I took my time and got the intake and exhaust taken off. The flash of the camera really emphasizes the magnitude of the leak.
After that I got the materials to make my redneck soda blasting cabinet. I'll let you guys know how it works out.
Wow, it looks like there was a fire or a bomb explosion.
I made on of those with your blower shoved inside clear tubing, it works but it uses ALOT of soda and a huge mess. My neighbors wouldn't even look at me for a few days, it covered everything. Can't wait to see what you come up with, it's gotta be better than mine.
I tried my hand at cleaning up the intake.
This is what it looked like before.
I cleaned it with degreaser and rinsed with denatured alcohol. (If I remember my chemistry correctly, the ethyl alcohol with mix well with any remaining water and help the water evaporate.)
Then I cleaned it with brake cleaner and a brass brush. I followed that with the redneck blasting cabinet and soda blasting. As Cliff mentioned, it takes a fair amount of baking soda, and it won't blast off too much.
I had to scrape off some of the excess grease with a razor scraper and picks. I followed that with some more brake cleaner and steel brush. Then finished with more blasting.
I use a brass wheel on the balance tube and blasted some of the other parts.
I rinsed all of the parts with water and sprayed again with denatured alcohol to remove the water quickly.
Guest
This topic is now closed to further replies.
