Took the engine (N42/N42)and trans out today. Engine will be bored 2.9 with flattops/ stage 3 cam/ ported head etc. 180-190 at the wheels would make me happy. It will sadly not be done this year.
Dropped off my propeller shaft off at Driveline Service of West Sac to get checked out and balanced. Car developed a horrid vibration starting at 50mph after changing to 4.11 gears. Changed out the U-joints and no difference so off to the shop with it! Wont surprise me if it bent or out of balance, it's kind of a kluge of used parts ;-)
I've been working on removing the 44 year old undercoating, it was nice to find original paint. Also decided to try using magnetic tools to check for and fish out loose rust in the frame rails through the existing drain holes. Here's what I found.
Spent a good bit of the day re-covering a rubber 280 steering wheel with leather. Before and after shots. Completed for under $20 (not including time and sore fingers). It was worth it
Edited by gwri8
added pic
I finished up the air dam install and early front bumper on the 260Z.
Old
New
I really enjoyed the project because it tested my fabrication skills.
You can read the details here: https://fiddlingwithzcars.wordpress.com/260z-air-dam-and-front-bumper/
Edited by SteveJ
Went to the monthly Caffeine & Gasoline Saturday morning.
Huge turnout of cars, probably 200 +
Only other S30 was a very clean stock lime 73, very nice.
It was Caffeine & Octane day in Atlanta, too. We're a little better organized through Facebook and the Georgia Z Club, so we had about 14 S30s and 3 S130s today.
Here's a link to the full picture set: Caffeine and Octane ? September 2014 Edition (173 photos) | Steve's CARtography
After that I drove the Z over to someone's house to help him with his 280ZX. After confirming it was a fuel pump issue, we got a new pump, he installed it, and the car roared back to life.
Between $200 and $250 for new rotors, calipers, pads, braided stainless hoses, paint, fluid and a 1 man bleeder that actually works for $6.
It takes a Village, of tools...
I'm considering moving my driving lamps from the provided holes to ones drilled slightly closer to the ends. The provided holes for the driving lamps are right behind the bumper over-riders, and the rubber projects down and blocks the upper half of the lamp and light. Good idea?
Guest
This topic is now closed to further replies.
