Posted December 31, 201311 yr comment_438786 Does anyone know how and where to get scarab emblems?? Link to comment https://www.classiczcars.com/forums/topic/48253-scarab-emblems/ Share on other sites More sharing options...
December 31, 201311 yr comment_438803 Do you own a Scarab ? Link to comment https://www.classiczcars.com/forums/topic/48253-scarab-emblems/#findComment-438803 Share on other sites More sharing options...
December 31, 201311 yr comment_438806 Do you own a Scarab ?were going to drop a 350 in one and would be nice to have so emblems for it would you be able to help us? Link to comment https://www.classiczcars.com/forums/topic/48253-scarab-emblems/#findComment-438806 Share on other sites More sharing options...
December 31, 201311 yr comment_438807 Well its acctually a Z and ZX and wanted to drop a 350 in the ZX and turn them both into scarabs eventually Link to comment https://www.classiczcars.com/forums/topic/48253-scarab-emblems/#findComment-438807 Share on other sites More sharing options...
December 31, 201311 yr comment_438810 The only Z's that had Scarab emblems were the Factory built Scarab cars. There were less than 200 built by Scarab engineering between 1976-81. Of these only 17 are known to exist. I maintain the Scarab Registry. The Scarab emblems are simply not available as they were on these cars only. Unless you find a parted out factory car (if you do let me know) I'm afraid you're out of luck. Also, are you using a Scarab kit (or at least the motor mounts) ?.. most use the JTR equipment as they are readily available.. Link to comment https://www.classiczcars.com/forums/topic/48253-scarab-emblems/#findComment-438810 Share on other sites More sharing options...
December 31, 201311 yr Author comment_438813 I was hoping for better news but thanks for the info. Where can I get those mounts? Link to comment https://www.classiczcars.com/forums/topic/48253-scarab-emblems/#findComment-438813 Share on other sites More sharing options...
December 31, 201311 yr comment_438816 I was hoping for better news but thanks for the info. Where can I get those mounts?Did you try a Google search for "JTR"? Worked for me.Dennis Link to comment https://www.classiczcars.com/forums/topic/48253-scarab-emblems/#findComment-438816 Share on other sites More sharing options...
