Posted December 31, 201311 yr comment_438788 I have a 81 280zxt My flasher fuse keeps blowing as soon as I touch fuse to holder POP!!! Instantly blows my mechanic friend unplugged the turn signal switch it doesn't blow the fuse in there is fine any input/help please & thanks Link to comment https://www.classiczcars.com/forums/topic/48254-turn-signal-fuse-keeps-blowing/ Share on other sites More sharing options...
December 31, 201311 yr comment_438794 You've probably got a loose bulb or wire in one of the fixtures. Take the screws out and remove the lenses for a look. Link to comment https://www.classiczcars.com/forums/topic/48254-turn-signal-fuse-keeps-blowing/#findComment-438794 Share on other sites More sharing options...
December 31, 201311 yr Author comment_438805 Do you mean the bulbs in the rear in the harness ? Link to comment https://www.classiczcars.com/forums/topic/48254-turn-signal-fuse-keeps-blowing/#findComment-438805 Share on other sites More sharing options...
December 31, 201311 yr comment_438809 You haven't supplied enough information to give a meaningful assessment.How long have you owned this car? Has the fuse always blown, or is this a recent occurrence? If it is recent, have you done anything to the car maintenance wise prior to the fuse blowing?Was the turn signal turned to the left or right when the fuse was blowing, or would the fuse blow with the switch in the center (off) position? Link to comment https://www.classiczcars.com/forums/topic/48254-turn-signal-fuse-keeps-blowing/#findComment-438809 Share on other sites More sharing options...
December 31, 201311 yr Author comment_438815 Sorry about not giving enough information. So here it goes I got the car in July. the dash wiring was a mess it was hacked up. One of the previous owners tried to but after market gauges in I've pulled all the carpet out the wiring from back until you get to the dash was not messed with the fuse problem has always been there they told me I needed to hook the lights. up but head & tail lights work my hazards work fine and when we put a blown fuse wrapped in tin foil in the holder the turn signals work then and i think its when you flip the switch in either direction it blows and there is a terminal strip by the steering column for extra power we've eliminated most of the mess by pulling those gauges out. Thanks. Link to comment https://www.classiczcars.com/forums/topic/48254-turn-signal-fuse-keeps-blowing/#findComment-438815 Share on other sites More sharing options...
December 31, 201311 yr comment_438822 If you have time, read this tech tip on your "combo Switch". Something might ding a bell in your head.http://www.kamikazeracing.org/dl/ZTech/Rebuild_240Z_combo_switch.pdfAnd unless this your only night time ride, don't do the tin foil wrapped fuse. You'll end up causing more problems. Edited December 31, 201311 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/48254-turn-signal-fuse-keeps-blowing/#findComment-438822 Share on other sites More sharing options...
January 1, 201411 yr Author comment_438848 I don't leave it like that just for a quick second to test it the car isn't drivable at the moment do to other problems but I've been trying to fix this turn signal problem since I got the car Link to comment https://www.classiczcars.com/forums/topic/48254-turn-signal-fuse-keeps-blowing/#findComment-438848 Share on other sites More sharing options...
