March 6, 200322 yr comment_28864 See my post back when the first auction was on for the reply I got from the seller. He said "This set up was designed specifically for the early Z cars, it uses a Bendex 4 big piston caliper set up from a 4x4 truck, vented rotors that I had slotted by a machine shop and all the spacers and hardware needed. As you can see I have this same set up on my $30K show car with a 3.2 stroker and it stops on a dime! This is a direct blot on in less then a hour .Good luck with your bid, its well worth ever penny, believe me only a few people have this set up, will you be one? " Link to comment https://www.classiczcars.com/forums/topic/4828-me-thinks-some-people-thing-others-are-tupid/?&page=2#findComment-28864 Share on other sites More sharing options...
