Posted January 10, 201411 yr comment_439358 My datsun 1972 240z did not brought the Tail light Panels that go under the tail lights. I already got the center panel and will purchase the left and right soon, however in order to install them i need to fasten them with some plastic rivets.I read that the parts number are the following:RIVET-PLASTIC 79909-E41002 questions:-Where can i purchase these plastic rivets?-How many will i need? Link to comment https://www.classiczcars.com/forums/topic/48321-plastic-rivets-for-240z-tail-light-panels/ Share on other sites More sharing options...
January 10, 201411 yr comment_439363 http://www.classiczcars.com/forums/interior-s30/40953-exterior-taillight-trim-piece-plastic-rivits.html Link to comment https://www.classiczcars.com/forums/topic/48321-plastic-rivets-for-240z-tail-light-panels/#findComment-439363 Share on other sites More sharing options...
January 10, 201411 yr comment_439376 They are available thru Courtesy Nissan Parts for $1.81 each. Plug your part # into the search box.Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com Link to comment https://www.classiczcars.com/forums/topic/48321-plastic-rivets-for-240z-tail-light-panels/#findComment-439376 Share on other sites More sharing options...
January 10, 201411 yr comment_439377 If you really want the original style rivets, you can pay the extra money, but at a place like mcmaster.com, you can get more for a LOT less. For the same amount of money, you can get 100 of a very similar style, You just need to measure the hole and depth required. They come in bags of 50 or 100.OTOH, I was able to get some very similar rivets from the local autoparts. they were black plastic and had a threaded center pin that you turned with a small Torx driver. Link to comment https://www.classiczcars.com/forums/topic/48321-plastic-rivets-for-240z-tail-light-panels/#findComment-439377 Share on other sites More sharing options...
January 12, 201411 yr comment_439477 I went with sheet metal screws. Unless the car is a Concours restoration, the screws are a much better option Link to comment https://www.classiczcars.com/forums/topic/48321-plastic-rivets-for-240z-tail-light-panels/#findComment-439477 Share on other sites More sharing options...
January 13, 201411 yr comment_439484 I avoid using screws to fasten things unless there already is a threaded hole. Screws chew up or scratch the paint, and that invites rust. Link to comment https://www.classiczcars.com/forums/topic/48321-plastic-rivets-for-240z-tail-light-panels/#findComment-439484 Share on other sites More sharing options...
January 13, 201411 yr comment_439487 I went with sheet metal screws. Unless the car is a Concours restoration, the screws are a much better optionI have used sheet medal screws before many times, they are quick and easy. But you are driving a piece of history.I try to modify with the next owner in mind, a little dab of sealant on a new screw/hole goes a long way. Link to comment https://www.classiczcars.com/forums/topic/48321-plastic-rivets-for-240z-tail-light-panels/#findComment-439487 Share on other sites More sharing options...
January 13, 201411 yr comment_439510 Good idea. Drill the hole, then put a blob of sealant over/through the hole, let it set up slightly, then drivethe screw through the wet sealant. Link to comment https://www.classiczcars.com/forums/topic/48321-plastic-rivets-for-240z-tail-light-panels/#findComment-439510 Share on other sites More sharing options...
January 20, 201411 yr comment_439952 I avoid using screws to fasten things unless there already is a threaded hole. Screws chew up or scratch the paint, and that invites rust.It's a sheet metal screw. The is no threaded hole as the screw uses the diameter of the hole to thread itself.I found a sheet metal screw that fit the diameter of the existing hole for the exterior tail light trim panel. It is not tearing anything up, I am not drilling a new hole nor am I threading anything. Maybe I am misunderstanding the part in question. Are they the four pieces on the rear deck under the hatch that secure the exterior tail light panels? Link to comment https://www.classiczcars.com/forums/topic/48321-plastic-rivets-for-240z-tail-light-panels/#findComment-439952 Share on other sites More sharing options...
January 20, 201411 yr comment_439965 IMO, anything with threads on it will chew up a hole, even if it fits well.I've seen an S30 with some pan-head screws used to fasten the taillight finishers. It was not unsightly, just different from what I'm use to seeing. Link to comment https://www.classiczcars.com/forums/topic/48321-plastic-rivets-for-240z-tail-light-panels/#findComment-439965 Share on other sites More sharing options...
