Posted January 14, 201411 yr comment_439587 This is going to be old news for many, but new to me. When I rebuilt the front brakes a few years ago I didn't use the no-squeal grease, because I wasn't sure where it went, and greasing the brakes seemed like a bad idea. Anyway the brakes have been extra squeaky the last week. So today I tried making a couple of hard stops (I don't usually break hard unless I have to). That fixed it somehow, no more squeals. Link to comment https://www.classiczcars.com/forums/topic/48342-quick-fix-for-squeaky-disk-brakes/ Share on other sites More sharing options...
January 14, 201411 yr comment_439636 Now that's a repair that I like. Nothing to tear down, just another good reason to go fast. I hope it continues to work for you. What brand brakes did you buy? It might help some of us to avoid the potential problem.Mark in Portland Link to comment https://www.classiczcars.com/forums/topic/48342-quick-fix-for-squeaky-disk-brakes/#findComment-439636 Share on other sites More sharing options...
January 14, 201411 yr comment_439637 Rotors were probably glazed over. You may have burned it away with aggressive braking. Link to comment https://www.classiczcars.com/forums/topic/48342-quick-fix-for-squeaky-disk-brakes/#findComment-439637 Share on other sites More sharing options...
January 15, 201411 yr comment_439646 I've tried the same fix. Results were temporary. Link to comment https://www.classiczcars.com/forums/topic/48342-quick-fix-for-squeaky-disk-brakes/#findComment-439646 Share on other sites More sharing options...
January 15, 201411 yr Author comment_439656 It's stock rotors and calipers, and street performance (IIRC) pads, all from MSA. And as I noticed today, yes, results were temporary, but repeatable. Link to comment https://www.classiczcars.com/forums/topic/48342-quick-fix-for-squeaky-disk-brakes/#findComment-439656 Share on other sites More sharing options...
January 15, 201411 yr comment_439693 Pull the brake pads, Assuming everything is dusty, dry and looking good, lightly sand the pads & discs using 220 or finer sandpaper in a tight circular motion, The idea is to remove the shiny glaze and make it look swirly. The auto-parts stores have a product in a tube that you squeeze onto the back of the pads, It reminded me of Tool Dip when I used it. I don't remember the name but there are probably many similar products out there. Good LuckMark in Portland Link to comment https://www.classiczcars.com/forums/topic/48342-quick-fix-for-squeaky-disk-brakes/#findComment-439693 Share on other sites More sharing options...
January 15, 201411 yr comment_439694 The factory-style steel shims that fit behind the pad will do the job. I had a set of pads that would not stop squealing until the shims were installed. Grease, the spray-on goo, chamfering the pad edges, none of it worked. Only the shims. You can get them at RockAuto for $1-4. "Brake Pad Shim Kit".I feel like a Debbie Downer.. Link to comment https://www.classiczcars.com/forums/topic/48342-quick-fix-for-squeaky-disk-brakes/#findComment-439694 Share on other sites More sharing options...
January 16, 201411 yr Author comment_439769 Guess I'll use the grease, sandpaper and shims, then. But my next brake project needs to be the rear ones. When I did the front brakes about 5 years ago they were really shot. Discs badly scored, calipers sticking, and pads gone. Guess the previous owner figured 130K miles without a brake job was OK. I'm guessing it's time to do the rear brakes.They didn't squeak yesterday so maybe the hard stop "fix" can last at least a couple days. Link to comment https://www.classiczcars.com/forums/topic/48342-quick-fix-for-squeaky-disk-brakes/#findComment-439769 Share on other sites More sharing options...
