Stop wearing those mini-skirts and stilletto heels...ROFL
Yes, you can raise it a bit, if you look there are plastic spacers under the seat already, or there should be anyways, you could always find another set of them and add them to what is there now.... Or you could have someone take the seat out and add a locknut to the mounting stud so that you could adjust the seat up and down, by using a nut on the top and bottom, you could adjust it to where you wanted....
Beware, you'll be making some really strange contortions to reach those mounts...Just make sure the neighbor doesn't have a camera in his hand if you do it...:devious: LOL
Bonnie:
You CAN get the seat higher, but as it's already been pointed out, you're limited to the length of the bolts that hold the seat down to the frame.
You might have better luck putting some sort of spacer between the rails and the seat bottom itself. Especially if you need 1-1/2". Have you considered getting a hard foam cushion?
2¢
The straps on the bottom of your seat might need to be replaced if they are stretched and old. This will give your seat less of a bucket feel and raise you up a bit. You can get the kits just about anywhere. The one that comes to mind is sold by datsunrestore.com.
Recently Browsing 0
