Posted January 23, 201411 yr comment_440168 I have a E31 head that is is excellent shape and I noticed that it has the bronze valve seats in it, they are also in excellent shape, do I need these replaced with steal ones, or should I not worry about it? Link to comment https://www.classiczcars.com/forums/topic/48401-bronze-valve-seats/ Share on other sites More sharing options...
January 23, 201411 yr comment_440169 Replace 'em.....w/o lead additives, they'll be pounded out shortly. IMO Link to comment https://www.classiczcars.com/forums/topic/48401-bronze-valve-seats/#findComment-440169 Share on other sites More sharing options...
January 23, 201411 yr comment_440175 Iv'e always heard to replace them. Link to comment https://www.classiczcars.com/forums/topic/48401-bronze-valve-seats/#findComment-440175 Share on other sites More sharing options...
January 23, 201411 yr Author comment_440186 Can I bore the old ones out an simply press fit the new ones in? I am a machinist, just don't know what the tolerances are like on this stuff Link to comment https://www.classiczcars.com/forums/topic/48401-bronze-valve-seats/#findComment-440186 Share on other sites More sharing options...
January 24, 201411 yr comment_440214 When I had my head redone the shop told me that the old seats had to be cut out, and that as a result they had to be replaced with larger seats and intake valves. So I bought the 280Z intake valves and seats. (44mm I think) This shop pretty much exclusively worked on aluminum cylinder heads. They had big ovens to heat them up so they could remove and install the seats, guides, and other steel parts. The machinist told me that if you get the head hot enough and give it a solid tap, all the steel parts will just fall out. ( He may have been exaggerating. ) Link to comment https://www.classiczcars.com/forums/topic/48401-bronze-valve-seats/#findComment-440214 Share on other sites More sharing options...
January 24, 201411 yr comment_440225 My bronze seats failed in my race car and I had them replaced with steel. It was only about $200 to replace the 6 intake seats and do a valve job. They did not have to cut them out. Link to comment https://www.classiczcars.com/forums/topic/48401-bronze-valve-seats/#findComment-440225 Share on other sites More sharing options...
January 24, 201411 yr comment_440234 Can I bore the old ones out an simply press fit the new ones in? I am a machinist, just don't know what the tolerances are like on this stuffThe replacement procedure is described in the Service Manual. It doesn't look too complex. They recommend boring them out, heating the head and pressing in the new ones. No tolerances given but maybe there's only one size and the hole is assumed to be untouched. After they're installed though they need to be ground to fit the valve. That's the part that takes the skill and is most important. If you're not going to grind them too you might as well have a shop do the whole job.You said you're a machinist so may know that but just in case... Link to comment https://www.classiczcars.com/forums/topic/48401-bronze-valve-seats/#findComment-440234 Share on other sites More sharing options...
January 24, 201411 yr Author comment_440278 I have a spare head that I just put in the oven at 380f, I will see if the old valve seats come out easily, if not I will keep turning it up. Link to comment https://www.classiczcars.com/forums/topic/48401-bronze-valve-seats/#findComment-440278 Share on other sites More sharing options...
January 24, 201411 yr Author comment_440279 What are your thoughts on this head? Link to comment https://www.classiczcars.com/forums/topic/48401-bronze-valve-seats/#findComment-440279 Share on other sites More sharing options...
January 24, 201411 yr Author comment_440280 Is it too far gone? Link to comment https://www.classiczcars.com/forums/topic/48401-bronze-valve-seats/#findComment-440280 Share on other sites More sharing options...
January 24, 201411 yr comment_440282 Eddy67,Anything can be repaired, but unless the head is a full race head and that's the only damage, it's scrap and you should look for a new one. Link to comment https://www.classiczcars.com/forums/topic/48401-bronze-valve-seats/#findComment-440282 Share on other sites More sharing options...
January 24, 201411 yr Author comment_440283 Its a shame, this one has never been machine down, still lots of thickness to it, and its straight Link to comment https://www.classiczcars.com/forums/topic/48401-bronze-valve-seats/#findComment-440283 Share on other sites More sharing options...
