I have a E31 head that is is excellent shape and I noticed that it has the bronze valve seats in it, they are also in excellent shape, do I need these replaced with steal ones, or should I not worry about it?
https://www.classiczcars.com/forums/topic/48401-bronze-valve-seats/
When I had my head redone the shop told me that the old seats had to be cut out, and that as a result they had to be replaced with larger seats and intake valves. So I bought the 280Z intake valves and seats. (44mm I think)
This shop pretty much exclusively worked on aluminum cylinder heads. They had big ovens to heat them up so they could remove and install the seats, guides, and other steel parts. The machinist told me that if you get the head hot enough and give it a solid tap, all the steel parts will just fall out. ( He may have been exaggerating. )
My bronze seats failed in my race car and I had them replaced with steel. It was only about $200 to replace the 6 intake seats and do a valve job. They did not have to cut them out.
Can I bore the old ones out an simply press fit the new ones in? I am a machinist, just don't know what the tolerances are like on this stuff
The replacement procedure is described in the Service Manual. It doesn't look too complex. They recommend boring them out, heating the head and pressing in the new ones. No tolerances given but maybe there's only one size and the hole is assumed to be untouched. After they're installed though they need to be ground to fit the valve. That's the part that takes the skill and is most important. If you're not going to grind them too you might as well have a shop do the whole job.
You said you're a machinist so may know that but just in case...
