Posted January 24, 201411 yr comment_440245 So, I picked up a car this afternoon. She's a bit rusty. OK, a lot rusty! In fact it might be extremely costly to save her. But there is hope! For where there was once life... ...there can be life once again. That is if I replace every part here. And every part here. I'm sure I can afford to replace everything in this photo. If I step on this it will just go away. Problem solved. I don't need to worry about this section - if I try real hard I can always just stare forward. But what is this! A donor car!? That's only half rusted... It is possible we just might hear this engine sing again... And this body roll with pride again... And this plate shine again... For her 50th birthday. Link to comment https://www.classiczcars.com/forums/topic/48409-hs30-00019/ Share on other sites More sharing options...
January 24, 201411 yr comment_440246 WOW great find! Link to comment https://www.classiczcars.com/forums/topic/48409-hs30-00019/#findComment-440246 Share on other sites More sharing options...
January 24, 201411 yr comment_440250 Glad it's you and not me! :tapemouth Link to comment https://www.classiczcars.com/forums/topic/48409-hs30-00019/#findComment-440250 Share on other sites More sharing options...
January 24, 201411 yr comment_440251 Awesome find!Chuck Link to comment https://www.classiczcars.com/forums/topic/48409-hs30-00019/#findComment-440251 Share on other sites More sharing options...
January 24, 201411 yr comment_440259 Awesome find. But no way to ever recoup even 50% of the money it would take to fix this up however. Props to you if you move ahead. I would name it Lazarus as you will have brought it back from the dead Steve Link to comment https://www.classiczcars.com/forums/topic/48409-hs30-00019/#findComment-440259 Share on other sites More sharing options...
January 24, 201411 yr comment_440263 It can be worth the money when you find a buyer in Japan. Link to comment https://www.classiczcars.com/forums/topic/48409-hs30-00019/#findComment-440263 Share on other sites More sharing options...
January 24, 201411 yr comment_440266 hLs-17 was yellow... do you think they did hs-19 in that batch? Link to comment https://www.classiczcars.com/forums/topic/48409-hs30-00019/#findComment-440266 Share on other sites More sharing options...
January 24, 201411 yr comment_440269 crazee1 said: Awesome find. But no way to ever recoup even 50% of the money it would take to fix this up however. Props to you if you move ahead. I would name it Lazarus as you will have brought it back from the dead Steve Maybe not, sheet metal work doesn't have to be expensive if you have the skills and time... if you have to let a body shop do it.. yes. Great find ! Would be awesome to see this restored back to glory.. Link to comment https://www.classiczcars.com/forums/topic/48409-hs30-00019/#findComment-440269 Share on other sites More sharing options...
January 24, 201411 yr comment_440270 So you keep all the metal around the VIN plates, and you keep the engine (or at least the short block). And you replace everything else! But... Very cool find! Link to comment https://www.classiczcars.com/forums/topic/48409-hs30-00019/#findComment-440270 Share on other sites More sharing options...
January 24, 201411 yr comment_440276 George, I cannot wait to follow this thread!What a task!Good luck.Dave Link to comment https://www.classiczcars.com/forums/topic/48409-hs30-00019/#findComment-440276 Share on other sites More sharing options...
January 24, 201411 yr comment_440295 A double digit VIN is probably worth trying to save. As others have mentioned, do as much of the work yourself as time permits. If you farm the work out, you probably won't recoup 50¢ on the dollar if you eventually sell in the next 30 years. I'm familiar with at least one rare Porsche being reconstructed around a VIN from a car that was too far gone to rebuild. Something to consider, depending on how you define the soul of a car.Dennis Link to comment https://www.classiczcars.com/forums/topic/48409-hs30-00019/#findComment-440295 Share on other sites More sharing options...
January 24, 201411 yr Author comment_440296 crazee1 said: Awesome find. But no way to ever recoup even 50% of the money it would take to fix this up however. Thanks Steve. I don't view this as an investment so I'm not concerned about recouping my costs. That happens all too rarely with cars anyway. Blue said: hLs-17 was yellow... do you think they did hs-19 in that batch? I need to confirm the colour code somehow. It looks to be one of the orange based ones. I'm guessing 920 at this stage. Link to comment https://www.classiczcars.com/forums/topic/48409-hs30-00019/#findComment-440296 Share on other sites More sharing options...
