Posted January 24, 201411 yr comment_440293 For those who have converted away from the mechanical linkage over to a throttle cable, I'm curious what anchor point you used on your SU carbs. Specifically did you mount a throttle wheel to the linkage or did you create some other form of connection? I'm just starting to do my homework as I'm not thrilled with the mechanical linkage. Any suggestions/pictures you have would be appreciated. Thanks! Link to comment https://www.classiczcars.com/forums/topic/48411-conversion-to-throttle-cable-su-anchor-point/ Share on other sites More sharing options...
January 30, 201411 yr comment_440688 Dave, I wish I had taken better pics when I had the cable throttle up and working on my SU's but you might be able to see how I did it from the 3rd pic. The H shaped holder mounts to the intake manifold between the heat shield and the bottom of the air box. One of the advantages to cable throttle control besides the smooth action is it allows you the get rid of all that crap on the balance tube. I have triples on the engine now and haven't got around to installing the cable linkage yet. Link to comment https://www.classiczcars.com/forums/topic/48411-conversion-to-throttle-cable-su-anchor-point/#findComment-440688 Share on other sites More sharing options...
January 31, 201411 yr comment_440786 Also, there are 2 possible problems you might run into, I certainly did.I found a couple of weeks after installing the cable linkage that either the cable stretched or a combination of other parts settled and the throttle plates weren't opening fully anymore. After adjusting all was fine again and there was no more problems with that. On the other end of that problem is the possibility of not having your gas pedal stop posistioned correctly and using the power of your foot and desire for speed to force the throttle plates too far.It's easy to add a spacer on top of the gas pedal stop if you have to.Chris Link to comment https://www.classiczcars.com/forums/topic/48411-conversion-to-throttle-cable-su-anchor-point/#findComment-440786 Share on other sites More sharing options...
February 1, 201411 yr comment_440809 Granny: do you use lokar cable on your triple SK setup as well? Link to comment https://www.classiczcars.com/forums/topic/48411-conversion-to-throttle-cable-su-anchor-point/#findComment-440809 Share on other sites More sharing options...
February 1, 201411 yr comment_440830 Haven't got to it yet,too busy rebuilding tranny. Reverend said: Granny: do you use lokar cable on your triple SK setup as well? Link to comment https://www.classiczcars.com/forums/topic/48411-conversion-to-throttle-cable-su-anchor-point/#findComment-440830 Share on other sites More sharing options...
February 19, 201411 yr Author comment_441883 I think I found the solution for anchoring to the SU throttle shaft. I'm taking some detailed pictures along the way as well.Aluminum Throttle Linkage Arms - Speedway Motors, America's Oldest Speed Shop Link to comment https://www.classiczcars.com/forums/topic/48411-conversion-to-throttle-cable-su-anchor-point/#findComment-441883 Share on other sites More sharing options...
February 20, 201411 yr comment_441896 I cannot make those for $10 bucks! Excellent find Dave! Order in! Link to comment https://www.classiczcars.com/forums/topic/48411-conversion-to-throttle-cable-su-anchor-point/#findComment-441896 Share on other sites More sharing options...
February 20, 201411 yr Author comment_441916 I went with the larger 3/8" size, although I think the SU shaft is a big larger, but I'm sure I can make it fit (possible grind down the throttle arm hole if required). There's also a lightweight on which has less material on it...same site. Enjoy! Link to comment https://www.classiczcars.com/forums/topic/48411-conversion-to-throttle-cable-su-anchor-point/#findComment-441916 Share on other sites More sharing options...
August 21, 201410 yr comment_453906 grannyknot said: [ATTACH=CONFIG]69540[/ATTACH]Where did you get the clean balance tube?Still trying to figure out what the h-plate does too.I am converting back to SUs from a Holley, so i have a cable, just need to connect it all.I am sure wisdom from Jim (zKars) will help. Link to comment https://www.classiczcars.com/forums/topic/48411-conversion-to-throttle-cable-su-anchor-point/#findComment-453906 Share on other sites More sharing options...
August 22, 201410 yr Author comment_453909 I believe the "H Plate" allows for a stop point for the cable housing. I ended up fabricating a bracket for mine. See Dave's 1972 Datsun 240z: Throttle Jerk Fix Link to comment https://www.classiczcars.com/forums/topic/48411-conversion-to-throttle-cable-su-anchor-point/#findComment-453909 Share on other sites More sharing options...
August 23, 201410 yr comment_454019 Thanks Dave - the blog entry really helps. Just wondering if you considered attaching the L-bracket to the air cleaner instead. Also wonder about just grinding the ball off of the stock connector and attaching the cable to it. I think the return to SUs will be fun Link to comment https://www.classiczcars.com/forums/topic/48411-conversion-to-throttle-cable-su-anchor-point/#findComment-454019 Share on other sites More sharing options...
August 24, 201410 yr Author comment_454065 The air cleaner would have made for a much cleaner install, but I didn't want to drill into it, so I opted for the heat-shield. After a bit of re-engineering the mechanical linkage I swapped back to that and it seems to work pretty well. If anyone is interested in my setup (see picture above), make me an offer. Link to comment https://www.classiczcars.com/forums/topic/48411-conversion-to-throttle-cable-su-anchor-point/#findComment-454065 Share on other sites More sharing options...
