Two post lift points for the 240?
SledZ
Pulled the trigger and have a Bendpak XPR-9 on the way. Looking for the best lift points under there or if someone has a picture of there car on a lift would be great. If anyone has experience lifting one let us know.
Thanks.
post-4287-14150827470735_thumb.jpgThanks John. I dug up my pictures from 12 years ago when I had it on jack stands. Is that the right place where my jack stand is in the picture or the very outside rear corner of the "tubbed out area just to the right of the jack stand?
Here's the detail from the General section of the FSM: "Front supportable points for stand are both front side members. Rear supportable points are both side of front differential mounting cross member." Photos show stands at the front box member where it tapers to smallest height (at the floor pan). Stands at the rear are pictured at the box member running across the car - just ahead of where your stand is located in the pic.
I've pondered just building some fixtures that mimic the shape at the top of the factory scissor jack and using the scissor jack lift points on the rocker panel of the car. Basically a piece of square tube with a slot cut in it. Easy to get to and under what should be one of the strongest structures of the body.
  • Who's Online   1 Member, 0 Anonymous, 751 Guests (See full list)
