I've made a serious effort making sure EVERYTHING works on my Z as it originally did. My first question is about the annoying buzzer that activates when I open the driver door. When I open the driver door, the buzzer goes on and the overhead light goes on. It doesn't matter if the key is in the ignition or not. It buzzes either way. Is it only supposed to buzz if the key is in the ignition? Question 2 is that the passenger door only activates the overhead light when opened. That's correct, right? Once I get this ironed out I should have everything functioning 100%! Yes the original clock works too. Thanks.
