LSD question
malibud
LSD's have a clutch or mechanism of some kind in the carrier (the center structure with the small gears in it) to distribute force to the wheels, where in your picture you just have four spider gears (the small gears). That's a good picture because it shows the spider gears and their shafts, no clutch.
People do weld the spider gears together to make the wheels turn together. Most load up with lots of weld material but it's probably not needed. The one in your picture could be welded even though it's not obvious.
Here are some links with pictures of R200 CLSD's. An R180 or R190 would look similar. The second and third pictures are the best because they show the ramping mechanism (the diamond shaped piece) that distributes the force through the clutch.
Nissan OEM 3.90 R200 LSD Diff Limited Slip Differential Clutch Type Datsun 240Z 260Z 280Z 280ZX 300ZX Z31 | Whitehead Performance
Datsunracing.com Image Gallery :: My '73 240Z :: lsd
http://www.nengun.com/nismo/nissan-motor-r200-lsd-for-mechanical-177132
Edited by Zed Head
One of the guys restoring a 240K sedan has an example of a R180 welded.
Its in post 145 of this thread: http://www.classiczcars.com/forums/open-240k-discussion/44259-terrys-project-240k-2.html
IMG_2335.jpg Photo by terry_350 | Photobucket
Shows what Zed is refering to about welding a standard (spider gear) diff.
Cheers Chas
Edited by EuroDat
Photobucket from Terrys project.
I wouldn't sugest doing it to a street car. I don't think Terry is that impressed with it either, but his car my have had a previous life as a "paddock basher".
That happens often in Australia. Farmers give their kids the old retired family car to dive around the farm and to give it better traction, they weld the diff.
Yep, been there, done that so to spreak.
Chas
  • Who's Online   2 Members, 0 Anonymous, 658 Guests (See full list)
