interior wiring harness question
timsz
Could someone tell me where the wiring harness should be located in the interior passenger side. From the firewall to the hole behind the seat. Does it lay against the rocker panel? Does it go under the seat? Does the emergency brake wire go behind the seat? 71Z Thank you very much, TimsZ
If it didn't show well enough in the pictures, the harness runs from under the kick panel, to beneath the vinyl rocker finisher along the seam of the interior
rocker panel and floor panel to the front passenger seat support. It then runs over the seat support as shown, and the emergency brake wire come off
at that point and runs behind that passenger front seat support over to the brake light switch on the brake lever.
  • Who's Online   1 Member, 0 Anonymous, 708 Guests (See full list)
