February 25, 200322 yr Author comment_27895 I looked at the way my dryer was hooked up and I'm copying it. I just can't see paying $50 bucks for someone to come out and do something that I feel I could do myself. If I paid to have stuff done all the time I wouldn't learn anything, and I'd be broke. I'll try anything atleast once. (Except licking my fingers to test the wiresLOL ) Link to comment https://www.classiczcars.com/forums/topic/4850-any-electricians/?&page=2#findComment-27895 Share on other sites More sharing options...
February 25, 200322 yr comment_27896 I strongly suggest that you get the Wiring Simplified book it is only $11 and will help make sure if your wire size is correct. Saving $11 is not worth burning down your home and maybe taking someone with Link to comment https://www.classiczcars.com/forums/topic/4850-any-electricians/?&page=2#findComment-27896 Share on other sites More sharing options...
February 25, 200322 yr comment_27900 If the cord has been previously hooked into a 220 outlet, the guage should be fine. After hooking it up, give it a bit a feel the wires for heat.In the event that you reverse the wires, which I have done, it will throw the breaker and you will need to try again. What I did was leave the outlet breaker in the off position, plug it in and go back over to the box and give 'er power. That way I'm not right next to the plug...I agree with both of you tho, a wiring book is good advice, but so is learning for yourself.Common sense applies in all of it.Good luck Ed, just leave the Z to me in the will.Just kiddingROFL B Link to comment https://www.classiczcars.com/forums/topic/4850-any-electricians/?&page=2#findComment-27900 Share on other sites More sharing options...
February 27, 200322 yr Author comment_28030 I did it. Hooked up the compressor, installed the breaker in the fuse box and turned it on. No problems runs like a charm. Either I'm lucky or just good.:classic: Link to comment https://www.classiczcars.com/forums/topic/4850-any-electricians/?&page=2#findComment-28030 Share on other sites More sharing options...
February 27, 200322 yr comment_28049 working with 240v can rearange your whole life. 110 is one thing but the 240 snake really bites hard. Maybe its so damn cold there your snakes are frozen . Get the book they are less than $11. at home depot and will come in handy if you are going to do any wireing in the garage or repairing any in the house. As a retired contractor please accept the advise. If the snake bites it's all over. Link to comment https://www.classiczcars.com/forums/topic/4850-any-electricians/?&page=2#findComment-28049 Share on other sites More sharing options...
