New to the forum here. I purchased a 1972 240z from a member here.
I want to replace the carb bowl to nozzle hoses. Does it matter what type of fuel hose I use? I saw this link and was wondering if it had to be thin or special type hose. SU CARB BOWL TO NOZZLE HOSE
https://www.classiczcars.com/forums/topic/48500-su-carb-bowl-to-nozzle-hose/
I've never tried anything aftermarket but the problem probably lies in the stiffness & possibly the diameter. The stiffness would likely bind up the nozzles when the choke is used and cause them to stick and eventually wear. My only source for them has been Ztherapy. Go for the good ones. One less thing to worry about.
Mark in Portland
Mark in Portland
