Posted February 5, 201411 yr comment_441079 I get the following error after every post. The post does go through though.[h=2]Errors[/h][h=3]The following errors occurred with your submission[/h]This forum requires that you wait 30 seconds between posts. Please try again in 29 seconds. Link to comment https://www.classiczcars.com/forums/topic/48504-error-when-posting/ Share on other sites More sharing options...
February 5, 201411 yr comment_441083 I can't post photos in Advanced mode. Link to comment https://www.classiczcars.com/forums/topic/48504-error-when-posting/#findComment-441083 Share on other sites More sharing options...
February 5, 201411 yr comment_441094 +1 on the first post. If you get antsy and push the post quick reply button you get two posts.Cheers, Mike Link to comment https://www.classiczcars.com/forums/topic/48504-error-when-posting/#findComment-441094 Share on other sites More sharing options...
February 5, 201411 yr comment_441097 Hmm, this must issues related to the anti-spam mod I installed recently. I'll look into it. Link to comment https://www.classiczcars.com/forums/topic/48504-error-when-posting/#findComment-441097 Share on other sites More sharing options...
February 5, 201411 yr comment_441099 Can you guys try again? I made a few changes and would like to know if it's fixed. Thanks. Link to comment https://www.classiczcars.com/forums/topic/48504-error-when-posting/#findComment-441099 Share on other sites More sharing options...
February 5, 201411 yr comment_441100 tamo3, Maybe the picture you want to post is too big or the resolution is too high? The max resolution I believe used to be 1250 horizontal pixels and there is a max MB file size which I don't know. Something I run into sometimes is that for whatever reason the photo upload doesn't work, or it works but it doesn't look like it worked. I just keep trying to upload the same photo, eventually the photo goes through. Do you hit a snag at any particular point in the upload process? Link to comment https://www.classiczcars.com/forums/topic/48504-error-when-posting/#findComment-441100 Share on other sites More sharing options...
February 5, 201411 yr comment_441102 Hey guys, I just made a few changes to the back-end. Can you try again for me? Link to comment https://www.classiczcars.com/forums/topic/48504-error-when-posting/#findComment-441102 Share on other sites More sharing options...
February 5, 201411 yr comment_441103 Hey guys, I just made a few changes to the back-end. Can you try again for me?Testing again Link to comment https://www.classiczcars.com/forums/topic/48504-error-when-posting/#findComment-441103 Share on other sites More sharing options...
February 5, 201411 yr comment_441104 Testing againTesting using quick reply Link to comment https://www.classiczcars.com/forums/topic/48504-error-when-posting/#findComment-441104 Share on other sites More sharing options...
February 5, 201411 yr comment_441105 Testing using quick replyTesting using advanced Link to comment https://www.classiczcars.com/forums/topic/48504-error-when-posting/#findComment-441105 Share on other sites More sharing options...
https://www.classiczcars.com/forums/topic/48504-error-when-posting/Share on other sites
