Email logins are now active ×
Subby r160 lsd
malibud
I am looking to buy a clutch LSD r160 from an old subaru any thoughts ? Is the LSD worth the 400$ ? I assume my handling will improve alone with some front and back sway bars. From what i read it will handle up to 200 hp. I may one day go to a turbo set up but nothing too crazy just stock. thanks for any input
Got to becareful what year you get. If I remember correctly only certain years allow you to swap out our halfshafts. If it's a direct swap, then 400$ isn't terrible. I think some 510 guy was running 400hp with that diff. Google around about that diff and you find some application guides for our datsuns.
Since the u-joints are replaceable I wonder if you could combine half-shafts to make a hybrid shaft that would work. Subie stub and flange on one side of the joint and the 240Z shaft, u-joint and flange on the other. It would only work if the u-joint was common or a suitable joint could be sourced.
For future reference, it would need to be a pre 1999 diff to have bolt in stub axles. They went to viscous type after that and our halfshafts won't work. I believe all the pre 99's were clutch type. search on the Ratsun sites for further info
Thanks for the info . Ratsun has been a big help looks they have the same spline count. If I was understanding it correctly he was taking out the viscous type out and putting a clutch style lsd in. May have found another I will keep you posted.
