Have a question for you guys. My Z is making a rather annoying squeaking noise from the front suspension occasionally. I took the tire off and tightened everything on the front suspension per torque specs. I do have a bit of a question. I replaced the brakes which required taking off all the hub and all. When I reinstalled it I tighted the hub bolt - the one that sits on the spindal - by hand and then a quarter or so turn with a wrench. If this was loose, could this cause any issues - persay a sound.
Ladies and Gents
Thanks
Jan
https://www.classiczcars.com/forums/topic/48532-spindal-bolts/Share on other sites
