Posted February 20, 201411 yr comment_441936 Hello, I recently purchased a urethane bumper. The inlet part is very wavy, I was wondering if anyone knew any way to straighten it out. Thanks, Han Link to comment https://www.classiczcars.com/forums/topic/48606-straightning-urethane-bumper/ Share on other sites More sharing options...
February 20, 201411 yr comment_441938 A little heat with a heat gun to slightly soften the piece, then flex and push on the piece to get it back into shape. Just be very careful not to use too much heat or you will distort the part. Link to comment https://www.classiczcars.com/forums/topic/48606-straightning-urethane-bumper/#findComment-441938 Share on other sites More sharing options...
February 20, 201411 yr comment_441942 If you can sandwich the defect between two straight pieces of wood or metal and clamp it down- then apply heat gun Link to comment https://www.classiczcars.com/forums/topic/48606-straightning-urethane-bumper/#findComment-441942 Share on other sites More sharing options...
February 20, 201411 yr comment_441943 madkaw said: If you can sandwich the defect between two straight pieces of wood or metal and clamp it down- then apply heat gunThat works well the only problem is half the time I've tried that the panel was slightly stretched. If that happens just heat push into the heated are and cool till the part is back into shape. Kind of like when you shrink metal with heat. Link to comment https://www.classiczcars.com/forums/topic/48606-straightning-urethane-bumper/#findComment-441943 Share on other sites More sharing options...
February 21, 201411 yr comment_441973 Which spoiler is that? I'm about to buy one from JEGS, it's a Xenon #3125, and was curious about the urethane being wavy. Seems like I read more and more about that problem. Thanks for any advice. Link to comment https://www.classiczcars.com/forums/topic/48606-straightning-urethane-bumper/#findComment-441973 Share on other sites More sharing options...
February 22, 201411 yr Author comment_442031 I don't have a part #, but it was listed as "Urethane Airdam with brake cooling ducts". Hope this helps. Link to comment https://www.classiczcars.com/forums/topic/48606-straightning-urethane-bumper/#findComment-442031 Share on other sites More sharing options...
