January 31, 20169 yr comment_485729 I thought it might be ground based on the diagram, but with lack a clear instructions left me with a bit a doubt. Could you snap a pic of how you ran it in your set up? Link to comment https://www.classiczcars.com/forums/topic/48627-very-cool-ignition-upgrade/?&page=9#findComment-485729 Share on other sites More sharing options...
January 31, 20169 yr comment_485751 I think that it makes sense when you realize that the thing with the short and long lines is the battery. They're showing the switch supplying power from the positive post of the battery and the blue wire connected to ground to the negative post. It's just an unusual symbol for the battery. Link to comment https://www.classiczcars.com/forums/topic/48627-very-cool-ignition-upgrade/?&page=9#findComment-485751 Share on other sites More sharing options...
February 3, 20169 yr comment_485935 45 years as a senior electronics technician here, that battery symbol is the same one that has been used for a battery for over a hundred years. Link to comment https://www.classiczcars.com/forums/topic/48627-very-cool-ignition-upgrade/?&page=9#findComment-485935 Share on other sites More sharing options...
February 3, 20169 yr comment_485950 Over here is a normal battery symbol. The one in the diagram is for a 4 celled battery. Link to comment https://www.classiczcars.com/forums/topic/48627-very-cool-ignition-upgrade/?&page=9#findComment-485950 Share on other sites More sharing options...
February 3, 20169 yr comment_485952 I meant unusual for general public consumption. I like the symbol that actually looks like a car battery. Especially good if you're trying to sell your product to non-technical people, for use in their cars. Typical problem with knowledge transfer to the public. Link to comment https://www.classiczcars.com/forums/topic/48627-very-cool-ignition-upgrade/?&page=9#findComment-485952 Share on other sites More sharing options...
February 3, 20169 yr comment_485960 I think its the difference between electronics industry and automotive electrics. Like the way we see resistors as a zig zag and in the electronics world I see it mostly as a rectangular symbol We use these symbols where I work mostly for loop sheets and such. http://www.circuitstoday.com/electronic-circuit-symbols Link to comment https://www.classiczcars.com/forums/topic/48627-very-cool-ignition-upgrade/?&page=9#findComment-485960 Share on other sites More sharing options...
February 24, 20169 yr comment_487123 Hello! Read somewhere by accident yesterday that the Mallory Unilite is out of production due to MSDs restructuring. First thought was to try buying one before everybody run out, but then I remembered reading about another even better solution a long time ago. Google helped me finding Ignition123 again, and after reading this very informative thread through it's stupid question time. 1. Understood this Datsun L6 attachment is US developed, at least it isn't listed on the .nl site. However the Swedish dealer that covers the nordic countries list it and I suppose it is the same product all over? Asking because I live in Finland... 2. As I like my car to look as original as possible, but pack a bit more power, I refuse to mount any aftermarket tachs. Also, I think non working original gauges are just as sloppy. What do you guys use? I guess you still need an adapter to be able to use the old original points friendly tach? 3. No ballast resistor with these even if you wanted to right? Link to comment https://www.classiczcars.com/forums/topic/48627-very-cool-ignition-upgrade/?&page=9#findComment-487123 Share on other sites More sharing options...
February 24, 20169 yr comment_487130 I think the 123 still uses a ballast resistor. It's described in the instructions, I think. Not sure it's a "high energy" electronic ignition, more of a programmable points replacement unit. Link to comment https://www.classiczcars.com/forums/topic/48627-very-cool-ignition-upgrade/?&page=9#findComment-487130 Share on other sites More sharing options...
February 25, 20169 yr comment_487146 The 123 system neither uses or does not use a ballast resistor. It requires between 2 and 3 ohms of primary coil resistance. So if you buy a 1 ohm coil, you have to add a 1 or 2 ohm ballast resistor in line with the +side of the coil to get to the 2-3 ohm target. If you buy a 3 ohm coil, then you skip the ballast resistor... Kapeesh? Okay one more thing to add. Having too little resistance just makes the coil and/or internal transistor switch burn out way before you hoped it would. It's all an operating current hence heat issue. If you HAVE to buy a 0.8 ohm MSD coil on the road somewhere due to a failure, don't sweat it. It will work just fine for weeks. Just don't leave it any longer than you have to. It's not an instant death sentence Edited February 25, 20169 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/48627-very-cool-ignition-upgrade/?&page=9#findComment-487146 Share on other sites More sharing options...
February 25, 20169 yr comment_487148 Good point. Funny though, I seem to remember noting in the past that the 123 did need more resistance on the primary than even a 1978 280Z for example (hence my "high energy" comment), but the recent instructions give a 1 ohm limit. The system also has an automatic shutoff which I don't recall. Who knows, they may have upgraded the electronics. All good. http://www.123ignitionusa.com/123switch6.pdf http://www.123ignitionusa.com/ p.s. I think/thought that it's "kapisch". But it turns out that it's actually capisce. Link to comment https://www.classiczcars.com/forums/topic/48627-very-cool-ignition-upgrade/?&page=9#findComment-487148 Share on other sites More sharing options...
May 18, 20168 yr comment_495309 Manuals and Software for the 123ignition are now found here as the 123ignitionusa site has changed a bit. And just a heads up the new Bluetooth version is available. http://123ignitionusa.com/pages.php?pageid=10 Link to comment https://www.classiczcars.com/forums/topic/48627-very-cool-ignition-upgrade/?&page=9#findComment-495309 Share on other sites More sharing options...
May 19, 20168 yr comment_495327 Planning to finally get one of these by the end of the year, glad to see improvements are being made! Link to comment https://www.classiczcars.com/forums/topic/48627-very-cool-ignition-upgrade/?&page=9#findComment-495327 Share on other sites More sharing options...
