November 15, 201410 yr comment_458656 Crazy camo! Must have been pretty bad to strip it down, looks like a lot of work. Nice new looking brake booster! Link to comment https://www.classiczcars.com/forums/topic/48675-just-ordered-my-rebello-30-now-what/?&page=12#findComment-458656 Share on other sites More sharing options...
November 15, 201410 yr Author comment_458657 It was pretty gnarly. the PO sort of spray painted it half assed and i think there was some truck bed liner rolled on in certain parts. I would have just put a new coat of paint on but i was pretty confident that it wouldn't stick, hence the strip Link to comment https://www.classiczcars.com/forums/topic/48675-just-ordered-my-rebello-30-now-what/?&page=12#findComment-458657 Share on other sites More sharing options...
November 15, 201410 yr comment_458670 What color is it going to be? Link to comment https://www.classiczcars.com/forums/topic/48675-just-ordered-my-rebello-30-now-what/?&page=12#findComment-458670 Share on other sites More sharing options...
November 16, 201410 yr Author comment_458715 Its an epoxy coat in black. Should be invincible Link to comment https://www.classiczcars.com/forums/topic/48675-just-ordered-my-rebello-30-now-what/?&page=12#findComment-458715 Share on other sites More sharing options...
November 19, 201410 yr comment_458864 So... Can anyone say with these Rebello 3.0 engines, that the valvetrain is much louder, almost like a diesel kind of sound in the valve cover when it's running? It's a new to me sound, my L24 never made. Link to comment https://www.classiczcars.com/forums/topic/48675-just-ordered-my-rebello-30-now-what/?&page=12#findComment-458864 Share on other sites More sharing options...
November 19, 201410 yr comment_458884 Interesting ! Trying to think why valve train would be much noisier? Maybe time to double check valve clearances? Link to comment https://www.classiczcars.com/forums/topic/48675-just-ordered-my-rebello-30-now-what/?&page=12#findComment-458884 Share on other sites More sharing options...
November 19, 201410 yr comment_458909 Well with only about 30 minutes of runtime since the break-in/dyno/re torque, I doubt it. Link to comment https://www.classiczcars.com/forums/topic/48675-just-ordered-my-rebello-30-now-what/?&page=12#findComment-458909 Share on other sites More sharing options...
November 20, 201410 yr comment_458936 Well with only about 30 minutes of runtime since the break-in/dyno/re torque, I doubt it. I don't. Valve clearances change rapidly during the break in period, as the valve and seat break in to each other. It's common to do many valve adjustments during the first ~1000 miles of a new engine, Link to comment https://www.classiczcars.com/forums/topic/48675-just-ordered-my-rebello-30-now-what/?&page=12#findComment-458936 Share on other sites More sharing options...
November 20, 201410 yr comment_458942 It's an easy quick check and necessary with solid lifter heads. Just check them and eliminate that, plus you can have a peek under the valve cover for anything else that looks odd. Link to comment https://www.classiczcars.com/forums/topic/48675-just-ordered-my-rebello-30-now-what/?&page=12#findComment-458942 Share on other sites More sharing options...
November 21, 201410 yr comment_459023 I can't push a 0.010" feeler between any of them with a 'warm' engine, and everything looks clean and tidy in there. When I have the time I'll take it for a good boot and adjust to 0.010/0.012 while hot. Read on Zcar that 0.001" is equivalent to 5* of cam timing on a stock L24, seems like an excessive amount, but the credentials sound legit. Any idea what Dave runs for lash on his cams, or would it vary each grind? Link to comment https://www.classiczcars.com/forums/topic/48675-just-ordered-my-rebello-30-now-what/?&page=12#findComment-459023 Share on other sites More sharing options...
November 21, 201410 yr comment_459029 I wouldn't trust any answer except from the builder Link to comment https://www.classiczcars.com/forums/topic/48675-just-ordered-my-rebello-30-now-what/?&page=12#findComment-459029 Share on other sites More sharing options...
November 21, 201410 yr comment_459031 Doesn't Rebello run their engines for a break-in period? Or is that only if you ask for a dyno sheet? Many of the performance cams run a tighter lash than stock. I agree with madkaw, just do exactly what the builder says to do. He's built hundreds or thousands of these. If it were mine, I would make a video or sound file and send it to him. You might have a problem that can be fixed before it does extra damage. Or even call him first and tell him it's very noisy. He might have a procedure he wants you to follow. On the lash - you can't stick a .010" in there but what can you? What is the actual measurement? Lash grows as the engine warms up, but if you're starting with a valve open when cold, you could "burn" or warp it. Best to get a real number. Bummer that it's not an easy break-in. Extra noise on a new engine is not normal. Link to comment https://www.classiczcars.com/forums/topic/48675-just-ordered-my-rebello-30-now-what/?&page=12#findComment-459031 Share on other sites More sharing options...
