Thanks Blue and Deseazd, Both good ideas I had not considered. If the vacuum cleaned does not work, how thick do you think the rubber should be? I picture it about 1/2 to 3/4 inch thick. What do you guys think?? Also I wonder what role the thing plays as far as how the booster works.
Thanks again for the replies, JB
Thanks again for the info. I will try again to fish it out and if not I plan to pull the booster. I don't think it would hurt to be left in there but I want it out. I still don't understand what role it plays. Anyway thanks for the help. I'll let you know the outcome. JB
That is what I have had going on. About the top 2/3 of the pedal travel nothing happens/ I have worn out the adjusters on the rear brakes and put brake fluid companies on overtime trying to bleed the air out.
I hope to get the disk out without removing the booster but will do that if I have to. I guess the disk has been missing since day one (for me) since I replaced every thing but the master cyl and could never get a full pedal. Then I replaced the master cyl and still had the same problem. Thanks everybody for all the good advise. JB
