How to test rear defroster glass grid
rpheitman
I have two (2) rear windows from a couple of Datsun 240Z Series 1 that I will be selling; however, I have no idea on how to test the defroster grid. Each window has two separate connection tabs to 'power' the grid(s); how do I test? Do you test the grids together, or are they two separate grids that are tested separately? How?
Thank you for any help you can provide.
There's a procedure in the FSM, using resistance measurements.
But an easier way might be to just to fog it up and apply battery voltage to the terminals. It's one grid, positive on one tab, negative to the other. Polarity doesn't matter.
  • Who's Online   1 Member, 0 Anonymous, 582 Guests (See full list)
