Well, I figure it this way, kill of one problem at a time until there are no more. If he can find a simple solution to the headlights, that leaves only 1 issue remaining and easier to figure it out... But I totally understand where you're coming from SteveJ
I will start with the alternator first, as it will at least let me drive to and from work without being stranded! =)
Thank you all for your suggestions btw. Like I said, worst comes to worse, I'll just slap the 50amp alternator back on and live with it. I'm thinking there's some work-around for the missing wire- just got to wait for those who've worked around it to reply.
EDIT: I did test the fuse-able links and power is going through both. And in the diagram that zedhead had post http://atlanticz.ca/zclub/techtips/fusiblelinks/index.html
the two fuse-able links are for ignition and alternator: not for headlights. See? I'm learning.... i think
Edited by nissanthanh
The path is not easy to trace, but the headlight circuit is protected by the black fusible link.
