Front Disk Problem.....
Polecat
Hello all
I am replacing the front disks on my S-30 early 72 with a new set of rotors I got from Amazon. I was putting things together with the hub/rotor assembly mounted onto the spindle, bearings set and torqued, the disk seemed to be 1/2 inch farther out then normal from the brake back cover. When I tried to install the caliper, it confirmed it. Like I said the bearings are properly seated and the spindle nut was in the right place with no visible problems and everything lined up.
Is there a difference in years and models of the front disk for the Z cars. Better yet, I would like to know the exact measurement of the disk shoulder(the hub mounting face and the rotor face) of a original set of rotors.
I think I got the wrong disks and just need that measurement to confirm it.
Thanks!
Polecat
I just did a quick check of the online catalogue and it shows a P/N change during the 240Z series (40206-E4100 --> 40206-E4101) but no effective date. Beginning in 08/1973 which should be the beginning of the '74 models of the 260Z the P/N went to 40206-N3100. Hope this helps resolve your question as to getting the correct parts.
  • Who's Online   0 Members, 0 Anonymous, 761 Guests (See full list)
