Posted February 26, 200322 yr comment_27935 So, it came with NGKs and should stay with NGKs, but what about the iridium, or platinum, or anything else? I'm in NY, so I have temperature variations between below freezing in the winter to well above hot in the summer, and I have a higher output coil and some decent spark wires. Should I just stick the 6es in there, or upgrade to something else?Thanks in advance,Chris Link to comment https://www.classiczcars.com/forums/topic/4878-spark-plugs-ngk-yeah/ Share on other sites More sharing options...
February 26, 200322 yr comment_27951 Yeah. Link to comment https://www.classiczcars.com/forums/topic/4878-spark-plugs-ngk-yeah/#findComment-27951 Share on other sites More sharing options...
February 26, 200322 yr comment_27966 I vote NGK also. Link to comment https://www.classiczcars.com/forums/topic/4878-spark-plugs-ngk-yeah/#findComment-27966 Share on other sites More sharing options...
February 26, 200322 yr comment_27971 I like the NGK or if you can find them the Nippo Denso U grooves. I probably spelled it wrong, but you get the idea. I have used these MANY MANY times, great plug!!As far ar those platnum, splitfires, those are JUNK. I can't throw them far enough away from my cars.- My small bit of knowledge and experience. Link to comment https://www.classiczcars.com/forums/topic/4878-spark-plugs-ngk-yeah/#findComment-27971 Share on other sites More sharing options...
February 26, 200322 yr comment_28017 I've been using normal NGK plugs for a long time now and I love them. Link to comment https://www.classiczcars.com/forums/topic/4878-spark-plugs-ngk-yeah/#findComment-28017 Share on other sites More sharing options...
February 27, 200322 yr comment_28023 I was running Champion Gold but seemed to have problems with oiling up (tired motor doesn't help.)Switched to NGK's on 1st son's advice as he is heavily involved in motorbike racing in Oz. As bikes rev at around 16000rpm, I followed his advice and haven't had a probem since.:classic: Link to comment https://www.classiczcars.com/forums/topic/4878-spark-plugs-ngk-yeah/#findComment-28023 Share on other sites More sharing options...
March 3, 200322 yr comment_28479 For a relatively stock 240-Z: NGK BP6ESFor a 240-Z with electronic ignition MSD etc: NGK BP6ES-11And always use NGK wires Link to comment https://www.classiczcars.com/forums/topic/4878-spark-plugs-ngk-yeah/#findComment-28479 Share on other sites More sharing options...
March 12, 200322 yr comment_29527 I agree 100% but you have my interest peaked, what is the difference with the -11 plug from the bp6es ? Link to comment https://www.classiczcars.com/forums/topic/4878-spark-plugs-ngk-yeah/#findComment-29527 Share on other sites More sharing options...
March 12, 200322 yr comment_29534 NGK's only and nothing else. with wires i would go either NGK also or MAGNECORE makes a great set of wires too Link to comment https://www.classiczcars.com/forums/topic/4878-spark-plugs-ngk-yeah/#findComment-29534 Share on other sites More sharing options...
March 12, 200322 yr comment_29537 Taylor 8mm Spiro Wires are good also Link to comment https://www.classiczcars.com/forums/topic/4878-spark-plugs-ngk-yeah/#findComment-29537 Share on other sites More sharing options...
March 13, 200322 yr Author comment_29555 ...for the replies. I already have the Magnecore wires (I think I got the 8mm ones..) and a higher output coil. I'm gonna grab some NGKs when I get a chance. Of course, when I wait for the weather to be above freezing, everything works almost immediately. Maybe I'm just impatiant, and the plugs aren't so tired after all.Thanks again,Chris Link to comment https://www.classiczcars.com/forums/topic/4878-spark-plugs-ngk-yeah/#findComment-29555 Share on other sites More sharing options...
