Email logins are now active ×
Transmission not separating from motor - clutch replacement job
gtom
for future readers: jacking and lowering at the tail of the transmission can apply some torque forces after the bolts are out to help loosen things a little.
Tapping around the margin between the motor and the transmission with a hammer can percussively loosen things with the tail jacked then released a little.
