March 19, 201411 yr comment_443721 for future readers: jacking and lowering at the tail of the transmission can apply some torque forces after the bolts are out to help loosen things a little.Tapping around the margin between the motor and the transmission with a hammer can percussively loosen things with the tail jacked then released a little. Link to comment https://www.classiczcars.com/forums/topic/48787-transmission-not-separating-from-motor-clutch-replacement-job/?&page=2#findComment-443721 Share on other sites More sharing options...
