patEOD92 Posted March 21, 2014 Share #1 Posted March 21, 2014 I just bought 72 240z and there is rust in the gas tank/fuel lines. What is the best way to fix this without replacing the parts, and if i have to replace the parts where can i find them Link to comment Share on other sites More sharing options...
siteunseen Posted March 21, 2014 Share #2 Posted March 21, 2014 (edited) Here's a start, Z Tech Tips Ball and Socket Compression Rod (AtlanticZ.ca).I did it and coated mine with Red-Kote.EDIT; It's not about ball and socket compression rod, it's how to rehab your gas tank, click on it. Edited March 21, 2014 by siteunseen Link to comment Share on other sites More sharing options...
patEOD92 Posted March 23, 2014 Author Share #3 Posted March 23, 2014 I used an air compressor o blow rust out of my fuel lines and put an octane booster in the gas that i was told would break up the rust for me. Cleanedy filter out and got a huge pile of rust. Hopefully this will solve the issue with a couple weeks of repeated filter cleanings. Link to comment Share on other sites More sharing options...
Mark Maras Posted March 23, 2014 Share #4 Posted March 23, 2014 Many years ago as I was driving my 71, the speed suddenly dropped to 45mph. 2nd, 3rd or 4th gear, same thing, 45mph. The engine would still sing at 6000rpms with the clutch in. It ran great up to 45, then nothing, no cut-out, no more power. My dad was the riding mechanic that day. Fortunately for me, he knew that it was lack of fuel & and it didn't matter what gear I was in, the engine only had enough fuel to push the car that speed. We pulled to the roadside, pulled the clear filter on the fire wall, blew it out ,yuck!, reinstalled it & problem was cured. I did change the filter that same day. I've shared this because it's possible you may run into this symptom in the future. It may be a good idea to carry spare filters & tools to replace them for a while. Mark in Portland Link to comment Share on other sites More sharing options...
Captain_Zeros Posted March 24, 2014 Share #5 Posted March 24, 2014 Hah, just an aside, I also had a 45 mph clogged filter once, it just took me more than one day to find it though. Had to stick to surface streets! Link to comment Share on other sites More sharing options...
patEOD92 Posted March 31, 2014 Author Share #6 Posted March 31, 2014 When my filter clogs it just kills the car. I used a compressor to blow out the fule lines and put a magnet in the tank as a temporary solution untill i have time/money to fix the tank Link to comment Share on other sites More sharing options...
siteunseen Posted March 31, 2014 Share #7 Posted March 31, 2014 If the lines are bad, my Dad cleaned some in an old truck he had by blowing a heavy fishing line through the line with a compressor. Then tied a .22 caliber wire gun cleaner tip and pulled it through. He had to do it a few times because of the rust but it must have worked, he drove it for years. I'd be scared of getting it stuck myself but you don't necessarily have to use the gun cleaner, maybe something smaller? Link to comment Share on other sites More sharing options...
