Is this OK?
siteunseen
The snorkel goes back to the engine bay. Could it be to prevent water satuating the filter when driving in a down pour or close behind another vehicle in rainy weather. The efficiency of a filter will reduce considerably when wet. That corner of the engine bay might be the dryest place they could find.
Chas
The thing is, olzed, the air would be cooler in front of the radiator than behind it.
Having once lived in a pretty dusty area, I would have guessed air from the engine compartment might carry a bit less dust than air from the front-side of the radiator, particularly if it had to circle back.
These snorkels extend down close to the road in some more recent models of cars. There have been cases in which engines would suck up massive amounts of water when driving through puddles. The water would then hydrolock the engine. Because the engine would be spinning at a good clip, naturally something would bust -- a piston rod, the crank shaft, or whatever. At least ours draw in air from up high.
  • Who's Online   0 Members, 0 Anonymous, 523 Guests (See full list)
