Posted February 26, 200322 yr comment_27998 OK before I go and start removing nuts and bolts I wanted to ask what to I undo to remove the seats. I have an 81 VW and there is one nut to remove and the seats slide off the tracks, is there anything like this or do I remove the four nuts that I think I need to remove to get the seats out. I realize this is sort of a stupid question but I want to just check.Bart Link to comment https://www.classiczcars.com/forums/topic/4890-seat-removal/ Share on other sites More sharing options...
February 26, 200322 yr comment_27999 I just removed mine about a month ago & it's simple. Just get a socket or wrench and remove the bolts.......It's four on each. Remove & Lift..... Link to comment https://www.classiczcars.com/forums/topic/4890-seat-removal/#findComment-27999 Share on other sites More sharing options...
February 26, 200322 yr comment_28009 If your car is a 72 or later and it is equipped with the seat belt warning system you'll also want to disconnect the seat pressure switch which is connected via a pig tail at the rear of the switch.2¢ Link to comment https://www.classiczcars.com/forums/topic/4890-seat-removal/#findComment-28009 Share on other sites More sharing options...
