260z seatbelt interlock.
idoxlr8
Thanks Steve, I thought so but not sure how to proceed from here.
I've eliminated the start button and firewall relay.
Any wisdom to share as far as jumping these to get my spark back?
I have the starter working by tapping into power off the firewall relay.
Any help appreciated.
Dean
Edited by idoxlr8
I have to take that back. It doesn't. I have to stop answering questions when I don't get much sleep the night before. If the interlock relay affected the running of the car, the emergency button wouldn't work.
Let's go back. You've made some electrical changes. Please identify all of the modifications you've made to the wiring, whether or not you think it will affect the running of the car.
Have you done any basic testing?
Do you have 12 VDC to the ballast resistor with the key in the ON position?
I do have 12 volts to the ballast. The only wiring changes were to the interlock system. Have a new coil as well.
I'm wondering if the 40 year old transistor box is suspect but the car ran fine before I pulled it down three years ago.
Are you sure all of the wiring to the ignition box and tachometer are correct and good? Either one could cause it not to run.
You could wire in an HEI as a temporary to test to see if it's the ignition box. Note: Disconnect the ignition box while running that test. An HEI is a relatively cheap test. You can get them for $12 plus shipping from Rockauto.
  • 3 weeks later...
