Fusible Links, car won't start
SilverStreak28
I have cleaned the corrosion off of the wires leading into my fusible links on several occasions and they still turn green with corrosion no matter what I do to them. Would upgrading to maxi fuses help this problem or do I need to replace part of if not all of the wiring harness? Car wants to turn over but will not start, replaced the fuel pump and checked the fuel pump relay. Always had a problem with my fusible links, but I let my car sit for over a year so now I can't exactly figure out whats wrong with it and I have nothing else to drive. Please help....
Can you hear the pump running? Is this an FI car? Do you have an eletrical tester, if not you can get them for really cheap at harbor freight. With that you can check for continuity between either side of the fusible links. If you know its getting fuel, then check your spark.
  • Who's Online   0 Members, 0 Anonymous, 650 Guests (See full list)
