My best 260Z yet!
grnsky
the steering wheel will sand down easily - work your way up to 500 grit then a furniture oil finish (i used lemon oil) will rub in and it will look fantastic and feel even better. even though it's not real wood, it has a great feel and will actually take a little oil nicely. some folks use heavy clear coats, but they feel a little "plastic-like" and you have to deal w/chips & flakes over time.
  • 2 months later...
Thanks Rossiz,
I decided to change directions with the build and drop in my 240's L28ET setup. There's the bottom end installed, head is getting some new seals.
Edited by grnsky
pic
  • 2 months later...
  • 2 months later...
  • 2 months later...
  • 2 months later...
Not a lot to report, some inter cooler piping, LS coil packs, etc. Definitely planning on stripping the red (Corvette) paint and taking it back to its original sky blue. But it will be awhile before that happens.
  • 10 months later...
Small updates, trying life with the custom intake, a new 90A alternator and a custom accelerator cable. She's almost ready to run, had some varnish in the fuel tank that needed scrubbing. Not running an oil cooler just yet.
