Recently Browsing 0
i've been having intermittent hard-starting, which has culminated in total non-starting.
the car has been my DD for a few months and i've replaced all the sensors, injector connectors, fuel lines and vacuum hoses. it either starts perfectly or starts after much cranking, then runs really well with no hint of fueling problems. at first i thought it was a hot-start issue, but now it will not start cold.
the plugs are dry, decent color and all are providing spark - i rested them on the valve cover and cranked the motor and saw them all fire in order. fuel pressure at the rail is 35-40 psi and fuel pump is running fine.
for some reason the injectors don't seem to be getting a signal. i put a voltmeter and then some LED's across the two terminals on the injector plugs and cranked the motor - no lights. is this the correct way to test them?
i'm pretty sure there is some kind of bad connection somewhere that is stopping the injectors from getting their signal/power/whatever and i haven't the foggiest how to even start diagnosis. i have the FSM and it is horribly confusing to an old carb guy... pin 37? continuity? wtf???
had the car towed home - for the second time, and can no longer rely on it as a useful source of transportation. the toughest part is that i absolutely love the stupid car. any help would be greatly appreciated.
https://www.classiczcars.com/forums/topic/49038-no-start-fuel-injectors-not-firing-1978-280z/Share on other sites
