Hanging RPM
Glliw
Just to be clear, you might need to seal the bottom tube also, to be sure. There are two passages in the manifold itself, the valve on top controls the flow between them. The plate will seal the passage but if the wall between has holes, it won't matter. You'll see how it works when you take the valve off the top. Look inside and you might see some damage. Just an improbable possibility.
  • Who's Online   2 Members, 0 Anonymous, 737 Guests (See full list)
