February 14, 201510 yr Author comment_463598 I see. It came that way, previous damage. I started in the middle of the pictures. Looks like your damper was going bad also. Do you have specs. on the engine. CR, valve lift, final displacement, etc.? I saw the general stuff but no numbers. The valve relief in those pistons has to lower CR. Just wondering. Looks like he's running 0.54 mm (0.021") "pop-up" on the pistons also. There was just an interesting thread on that a few days ago. Thanks for posting. You see, when you throw numbers at me like that, you're flying a plane that soars way past my head's capable radar, haha. As I mentioned in my post, I'm still learning about the whole process, so I'm no motor-guru like you lads.The CR should sit snug somewhere between 10.5 to 11, but according to Mr. Hosomi, the motor will feed just fine on 91 octane without throwing a fit. The displacement should allocate around 3.0 Litres.The Cam duration is .300 and the lift is .560 .290 and the lift is .490 if my memory serves me right (more often than not, it doesn't.) I want the car to idle nicely and be able to drive around town, but I'm not really looking for a Prius here. If it raises hell everywhere it goes, I'm fine with that! According to Eiji, though, his setup will run very smooth. Link to comment https://www.classiczcars.com/forums/topic/49063-building-a-l28-na/?&page=10#findComment-463598 Share on other sites More sharing options...
February 14, 201510 yr comment_463599 beautiful! Link to comment https://www.classiczcars.com/forums/topic/49063-building-a-l28-na/?&page=10#findComment-463599 Share on other sites More sharing options...
February 14, 201510 yr comment_463606 Love to see the official build sheet on the engine too! Well at least what info is willing to share. I saw that to Zed, I presume .021 above deck, but would like to be sure. Anything done to the crank?Thanks for sharing the pics-engine porn! Link to comment https://www.classiczcars.com/forums/topic/49063-building-a-l28-na/?&page=10#findComment-463606 Share on other sites More sharing options...
February 15, 201510 yr Author comment_463612 Love to see the official build sheet on the engine too! Well at least what info is willing to share. I saw that to Zed, I presume .021 above deck, but would like to be sure. Anything done to the crank?Thanks for sharing the pics-engine porn! Thanks all of you for helping me and supporting the build! Really helps in keeping it all going. I updated some simple specs on the front page. Link to comment https://www.classiczcars.com/forums/topic/49063-building-a-l28-na/?&page=10#findComment-463612 Share on other sites More sharing options...
May 23, 20159 yr Author comment_470372 Engine album updated! Link to comment https://www.classiczcars.com/forums/topic/49063-building-a-l28-na/?&page=10#findComment-470372 Share on other sites More sharing options...
June 24, 20159 yr Author comment_472608 Engine arrived! Pics coming soon... Link to comment https://www.classiczcars.com/forums/topic/49063-building-a-l28-na/?&page=10#findComment-472608 Share on other sites More sharing options...
July 11, 20159 yr Author comment_473639 So far, this is the only pic I've taken. Been busy with work and school. I'll undress her later and take some pictures for you guys Link to comment https://www.classiczcars.com/forums/topic/49063-building-a-l28-na/?&page=10#findComment-473639 Share on other sites More sharing options...
February 7, 20169 yr Author comment_486150 The stock EFI Engine: Engine out of the car: New Engine out of the Car: New Engine in the Car (Pardon the mess from the oily hands!): Link to comment https://www.classiczcars.com/forums/topic/49063-building-a-l28-na/?&page=10#findComment-486150 Share on other sites More sharing options...
February 7, 20169 yr comment_486152 Like that! triples... Link to comment https://www.classiczcars.com/forums/topic/49063-building-a-l28-na/?&page=10#findComment-486152 Share on other sites More sharing options...
February 7, 20169 yr comment_486153 Very nice! Link to comment https://www.classiczcars.com/forums/topic/49063-building-a-l28-na/?&page=10#findComment-486153 Share on other sites More sharing options...
February 7, 20169 yr comment_486157 Now make it run!! Link to comment https://www.classiczcars.com/forums/topic/49063-building-a-l28-na/?&page=10#findComment-486157 Share on other sites More sharing options...
February 7, 20169 yr Author comment_486158 23 minutes ago, madkaw said: Now make it run!! Working on it! I'll post a video of it once it's running Link to comment https://www.classiczcars.com/forums/topic/49063-building-a-l28-na/?&page=10#findComment-486158 Share on other sites More sharing options...
