Posted April 22, 201411 yr comment_446356 So my 77 has a head gasket leak on both sides of the head. Been leaking for several years. Not bad, just kinda seeping until recently. Seems to be leaking a little more now, I think. Think its time to do something about it. But I'm not ready to remove the head and replace the gasket. Does anyone NOT recommend stop leak additives and if so, why? I hear it can plug other passages. But what are my odds of that happening? My cooling system is in great shape. Very clean. Coolant in the Aluminum rad and overflow bottle is very clean looking. Don't see any debris of any kind. Not sure if that matters when putting an additive in. If I have to pull the head I'm going to feel obligated to do other things as well, not ready for that either. Guess I'm looking for a bandage and not a band aid so to speak until later this year when I can possibly have the time to remove the head.Was going to take a couple pics but cant find the camera! Guess you know what I'm doing next.Thanks for your input. Edited April 22, 201411 yr by rcb280z Link to comment https://www.classiczcars.com/forums/topic/49087-head-gasket-leak/ Share on other sites More sharing options...
April 22, 201411 yr comment_446357 I have heard more pros then cons on the additives. It's more of a matter whether it will fix the problem then doing damage. IMHO I would give it a shot! Link to comment https://www.classiczcars.com/forums/topic/49087-head-gasket-leak/#findComment-446357 Share on other sites More sharing options...
April 22, 201411 yr comment_446360 It worked for me on a bigger leak at the back of the head. Mine actually dripped down the back of the engine while warming up. If you just have seepage, the odds are good. Bar's seems to be the popular one. Link to comment https://www.classiczcars.com/forums/topic/49087-head-gasket-leak/#findComment-446360 Share on other sites More sharing options...
April 22, 201411 yr Author comment_446373 Yea, I looked online and found Bars aluma seal I believe its called. $8 and if it works that is a cheap "bandage". Here are the pics. Link to comment https://www.classiczcars.com/forums/topic/49087-head-gasket-leak/#findComment-446373 Share on other sites More sharing options...
April 22, 201411 yr Author comment_446374 Here is a good pic of the gasket. If you zoom in and pan to the right you can see the gasket looks mangled. Hope the stop leak helps. Link to comment https://www.classiczcars.com/forums/topic/49087-head-gasket-leak/#findComment-446374 Share on other sites More sharing options...
April 23, 201411 yr Author comment_446385 Zed, do you remember which one you used? Bar's has so many and they range from $4-$60. They have one specific to head gaskets but for a "blown" head gasket. Mine is not blown so I think I may go with the "alumaseal" one. Link to comment https://www.classiczcars.com/forums/topic/49087-head-gasket-leak/#findComment-446385 Share on other sites More sharing options...
April 23, 201411 yr comment_446390 Sorry, but I can't remember exactly which I used. It only worked for a while then extruded itself out of the leak area, leaving a small mound of stop-leak at the spot. I should have mentioned that before.Have you been on the web site? They have a guide, based on leak type. Click on Cooling under Not sure .... Good luck, I see that yours has been dribbling for a while, based on the stain pattern.Bar's Leaks & Rislone - Premium Automotive Chemicals Link to comment https://www.classiczcars.com/forums/topic/49087-head-gasket-leak/#findComment-446390 Share on other sites More sharing options...
April 23, 201411 yr Author comment_446391 Yeah as a matter of fact I am going with the Liquid aluminum product. Thanks for the info.I'm going to try it and if it fails well...... Link to comment https://www.classiczcars.com/forums/topic/49087-head-gasket-leak/#findComment-446391 Share on other sites More sharing options...
April 28, 201410 yr comment_446778 How did that work out for you ? mine is weeping a bit also but the gasket looks to be in decent shape. Link to comment https://www.classiczcars.com/forums/topic/49087-head-gasket-leak/#findComment-446778 Share on other sites More sharing options...
August 12, 201410 yr comment_453198 Any word on this, mine is doing the same thing. Why does this happen so often? Link to comment https://www.classiczcars.com/forums/topic/49087-head-gasket-leak/#findComment-453198 Share on other sites More sharing options...
