Swaybar Paint advice
HuD 91gt
Hello,
My Front sway bar end links and bushings arrived, and I thought I might as well try and sand the bar down (I don't have access to a sand blaster) and give it a quick shot of paint.
Any suggestions for paint? How much does a sway bar flex, will I need a special flexible paint?
Edited by HuD 91gt
When I did mine, I used the same paint that I used on all of my suspension parts and that was Eastwood rust encapsulator (as a primer) and Eastwood Extreme Chassis Black as a top coat. Came out great and I have not noticed any flaws in the paint from flexing or any other movement that may take place with that part.
Although I was very satisfied with the result, if I had to do it over again I would have it (and all of my suspension parts) power coated as I believe this will ultimately hold up better than paint in the long run.
Hope this helps.
Mike.
I recommend an acid-cleaning product similar to POR's Metal Ready after you strip all the old paint and rust. If going with POR-15 paint, this is their recommended prep and is a good step for any paint process. If you're using another type paint, use a self-etching primer to get a good seal down into the metal.
^ Thanks for the suggestion. I didn't end up getting paint or POR as I was unsure of a primer. So this info is greatly appreciated. Wire brush is cleaning it up nicely. Although after picking up some callipers today, I realized the thing is 1"!! I think i'll need different bushings too. But where does one get aftermarket bushings for an unknown bar?
Really, any Black oil based paint would be fine, but there is no fun in that - especially if you have POR around...
I had mine powder coated with the rest of my suspension..
I would recommend soap and water for the flip flops ..... :)
Well, I think i'm going to go with MOOG universal 1" sway bar mounts. I stripped, etched/primed and painted the bar today. I then test fitted the sway bar end links I had purchased for a 240z replacement part. The bolts themselves are the same length as what was on there, but the bushings are quite a bit thicker and I don't have enough thread to get the nuts on. Anyone see any harm in cutting the middle spacer (Between the bushing caps) and 1/4-1/2 Inch to get a few threads showing?
  • Who's Online   2 Members, 1 Anonymous, 650 Guests (See full list)
