Posted April 25, 201410 yr comment_446567 Looks like I have a coolant leak between the head and the block, right near the back of the engine, close to the transmission. I'm assuming this is clearly a head gasket? Not having much luck with this car so far. The oil is still clear (Not milky). Edit: Sorry. the photo is upside down, I can't figure out why. It's upright on my computer. Link to comment https://www.classiczcars.com/forums/topic/49111-coolant-leak/ Share on other sites More sharing options...
April 25, 201410 yr comment_446568 I had a similar leak, bit on the other side. After I removed the engine (put another in), I removed the head and all of the other sealing areas were fine. It only leaked from a coolant passage outward. Rotated your picture for you. Link to comment https://www.classiczcars.com/forums/topic/49111-coolant-leak/#findComment-446568 Share on other sites More sharing options...
April 25, 201410 yr Author comment_446570 Thanks for the picture rotation!Good to know it's possible it could only be a coolant leak. I guess the only real way to check is to do a compression test?Is there any other heads I could swap on here that won't drastically reduce my compression ratio, yet increase performance a little over my E88? I can't seem to find an engine calculator that works for the L24 block.If a HG replacement is required, it would be nice to be able to swap on a useable/straight head right away and have the car on the road again the same day. Link to comment https://www.classiczcars.com/forums/topic/49111-coolant-leak/#findComment-446570 Share on other sites More sharing options...
April 25, 201410 yr comment_446571 If a HG replacement is required, it would be nice to be able to swap on a useable/straight head right away and have the car on the road again the same day.What engine/car are you working with? Link to comment https://www.classiczcars.com/forums/topic/49111-coolant-leak/#findComment-446571 Share on other sites More sharing options...
April 25, 201410 yr Author comment_446575 1971 240z L24 w/E88 head. Stock, SU carbs Link to comment https://www.classiczcars.com/forums/topic/49111-coolant-leak/#findComment-446575 Share on other sites More sharing options...
