Hello,
Just swapped out the points, cap, rotor, and 1 of the two condenser's on my 1971 240z.
I couldn't unscrew the "automatic" condenser without some clever contraption without taking the distributor off, so for now I just replaced the standard one.
Now my question is, I took out what was a Nissan branded condenser and on the side it had a Rating of 0.22somethings (Funny symbol), the one I replaced it with is 0.25somethings. I purchased it off RockAuto and it said it was a OEM replacement so i'm a little concerned that it's not the same. The car fired right up, but it is still not running 100% correctly (Other issues) so I don't know if this is something I should worry about or not.
Any one experience this before?
https://www.classiczcars.com/forums/topic/49118-l24-condensor-question/
No need to worry as long as your
replacement is automotive grade.
.25 vs .22 is well within the normal
tolerance of that application.
BTW: uF stands for microFarad, a
measurement of capacitance.
Mike
Edited by PastorMike
