My Datsun 280Z "Rustoration"
HaZmatt
I installed my MSD box today. Still need to run a couple more wires but its pretty straight forward. I mounted it in the drivers kick panel where the EFI unit was.
First I mounted the insulators
post-28616-0-02851800-1425006140_thumb.j
Then the box. It fits nice in there
post-28616-0-32078200-1425006145_thumb.j
Heres a couple shots of my engine bay. I still need to tidy things up and route my fuel lines better.
post-28616-0-17095900-1425006151_thumb.j
post-28616-0-45314000-1425006158_thumb.j
You should add a 90 degree fitting at the crankcase vent output an then route the hose towards the front of the engine and then over to the catchcan. Maybe you could find a preformed hose with a 90 in it already.... That would be nice!
Sent from my iPizzle ringy dingy device....
The metal tube that goes into the block has a 45 degree bend that is about 4" long. The straight tube that originally came in the block was "lost". So he sent me this one. If I angle it forward the tube will be too close to the fan. I might address this issue later on, but right now I just wanna get this thing running  :P
Did some re-reading and answered my own question...
"I also installed my firewall insulator I got from Black Dragon. Its good quality material but the fit isnt the greatest. It required some trimming."
So much good info in this thread!
  • Who's Online   1 Member, 1 Anonymous, 705 Guests (See full list)
