My Datsun 280Z "Rustoration"
HaZmatt
Matt, Looks great! Not to be Debbie downer, but that exhaust pipe looks pretty close to the ground. You will scrape it...been there, done that...no t-shirt.
Cheers, Mike
I hear ya, but the exhaust guy put it up as close to the body as he could with 2.5" piping. I guess i'll just have to be careful. :rolleyes:
So you have some spare voltage. I have a 210 amp welder. I wasn't sure your welds were penetrating as much as they could. I would have probably turned it up a bit but I don't think you will have an issue. Most of the load on the strust is compression. I like to be sure my welds burn in a little more around the edges. If you look at the welds in "Careless's"??  thread his puddles lay down a little more. He is TIGing I believe but the same principle. When I see them sort of bead up like water on oil I add some heat.
post-22019-0-48076400-1431900246_thumb.j
Thats an excellent pic of the different welds. Yeah on my first strut the voltage was too low. By the third one I had it down good. But like I said I would've felt confident in just doing a few tack welds because the coilover slides over the housing really nice and tight.
Yeah, I didn't think it would be a problem either. I guess the largest forces on the welds are them trying to rotate from braking or acceleration. With the whole circumference welded it aught to be fine.
